Post new topic Reply to topic  [ 1 post ]
 Post subject: CopyPasteExternal-copy/paste geometry between 3D apps
PostPosted: Thu Jun 08, 2017 3:13 pm
Туулче с МНОГО потенциал да стане нещо читаво:
Open source tool that will allow you to copy and paste geometry between 3D applications. Not only geometry but surface/material names, SubDs, weight maps, UV maps.
https://vimeo.com/215360965
The following applications are supported:
Modo : Vertices / Polygons (incl. Subpatch and SubD)/ WeightMaps / UVMaps / MorphMaps
Lightwave : Vertices / Polygons (incl. Subpatch and SubD)/ WeightMaps / UVMaps / MorphMaps
Blender : Vertices / Polygons (incl. Subpatch and SubD)/ WeightMaps / UVMaps / MorphMaps
Maya : Vertices / Polygons / Weights (via Vertex Normals) (Implementation by Andre Hotz)
Houdini : Vertices / Polygons / Weightmaps / VMaps
Rhino : Vertices / Polygons (should be a good starting point for someone more experienced to finish it)
Sketchup : Vertices / Polygons (Paste only for now - Initial implementation provided as starting point)
3DsMax : Vertices / Poyygons (Initial implementation provided as a starting point)
XSI : Vertices / Polygons / WeightMaps / Morphs
Others : Looking for contributors to write implementations for other 3d Apps (see TODO)
https://heimlich1024.github.io/OD_CopyPasteExternal/
https://www.behance.net/hristo_dinev
